o2 sensor bank1 sensor1
Old Jul 17, 2005 | 10:07 AM
jedinpa's Avatar
Default o2 sensor bank1 sensor1
I have a 00' 3.4 which keeps throwing this code. Replaced this sensor and check engine light came back on 20 minutes later. There is a pinging noise in the engine when under load. I'm thinking there is a air leak somewhere causing it to run lean. Or another sensor going bad causing the engine to run lean which would throw this code cause the sensor couldn't compensate for the problem<IMG src=smileys/smiley5.gif border="0">Any suggestions would help, I'm stumped<IMG src=smileys/smiley7.gif border="0"> Would like to condsider all possabilities before replacing intake gasket.<edited><editID>jedinpa</editID><editDate>38551.8824652778</editDate></edited>
Old Jul 22, 2005 | 01:09 PM
Patrick's Avatar
Administrator
is the CAT new, or newer?
Old Jul 22, 2005 | 11:10 PM
jedinpa's Avatar
CAT is still stock. It has never been replaced.
Old Jul 25, 2005 | 02:16 PM
scott4wv37's Avatar
I have the same problem with the o2 code, what did you find out that it is, have replaced the o2 sensor, fuel filter, spark plugs, cleaned mass air flow sensor and thinking about the TPS next
Old Jul 25, 2005 | 04:27 PM
Patrick's Avatar
Administrator
i have seen issues where the O2 sensors are repeatedly going bad because of problems with the CAT...not on this particular vehicle, but in general. do you have unusually high mileage?
Old Jul 25, 2005 | 07:00 PM
  #6
scott4wv37's Avatar
No, not for a toyota. Only 93,000. It maybe that my mass air flow sensor is bad b/c I've already cleaned it. ???????
Old Jul 25, 2005 | 07:04 PM
  #7
scott4wv37's Avatar
The problem is when I push the throttle down quickly there's a hesitation. If I put it to the floor theres an even longer hesitation.<IMG src=smileys/smiley6.gif border="0"></P>
Old Jul 27, 2005 | 10:21 PM
  #8
jedinpa's Avatar
</P>
</P>
Only 73,000 miles young, can't imagine cat is plugged but I'll pull it off and have a look.</P>
Old Jul 28, 2005 | 03:56 PM
  #9
scott4wv37's Avatar
<IMG src=smileys/smiley1.gif border="0"> FIXED !!! It ended up being a bad gasket where I had replaced the O2 sensor !
Old Jul 29, 2005 | 07:14 PM
  #10
jedinpa's Avatar
</P>
Thats great you got it fixed!<IMG src=smileys/smiley4.gif border="0"> Were you having any pinging noise in engine when accellerating? Truck goes to dealer on monday to see if they can figure it out<IMG src=smileys/smiley5.gif border="0"></P>
Heres the crazy part, the same day I scheduled the appt., the cellight went out on its ownbut pinging in engine is still there.</P>
cat3rn
Jan 25, 2015 11:08 PM
KJO
Sep 26, 2013 08:28 PM
lydias78
Oct 2, 2008 03:56 PM
gmcgough
Sep 14, 2007 10:28 PM
bjsurveyor
Nov 16, 2005 03:00 PM
