1st gen speedo
1st gen speedo
my speedometer hasn't worked since i bought the truck. After a little inspecting i found the gear on the end of the speedo cable that goes into the t-case was wore completely down.I'm running stock 4.10 gears with 35 inch tires, does anyone know what gear i should get to compensate for the tires? by the way its an 86, manual, 4x4, 22re
