BRAKE FAILURE pedal hard to push
Old Sep 13, 2013 | 06:33 AM
caperatheart's Avatar
Default BRAKE FAILURE pedal hard to push
Had a brake failure, abs and brake lights came on, high pitched alarm going off. no movement in brake pedal. can get it to stop vehicle if just coasting but have to push extremely hard. Mechanic says " abs pump and says part is 4000 bucks" had codes read and they are as follows:
c1223- malfunction in abs control
c1251- pump motor is locked/open circuit
c1252- hydroboost pump motor malfunction
c1256- accumulator low pressure malfunction
c1336- 0 point calibration of yaw rate sensor undone
c1340- open circuit in center diff lock signal
any help would be appreciated
2003 4runner sr5 (canadian) 6cyl, 139,000 km
Old Sep 14, 2013 | 08:33 PM
jtimports's Avatar
Sounds about right, check EBAY or online for a cheaper one.
Old Nov 25, 2013 | 09:08 PM
ambrosearchibald's Avatar
Thanks for the nice sharing,i have never know about it.
Old Nov 26, 2013 | 05:25 AM
farooq44's Avatar
Thank you for sharing your thoughts. Your article shows tells me you must have a lot of background in this topic.
Old Nov 26, 2013 | 06:15 AM
Default update
I purchased a used abs pump/master cylinder unit on ebay and had it delivered to Nova Scotia, and then paid a mechanic to install it. All together for the part, delivery and repair cost me about
$1100 after tax. Not bad at all considering Toyota wanted 4000 plus tax just to buy the part.
It has been working great ever since.
Feb 19, 2024 01:52 AM
amandanoraa
Mar 12, 2023 08:24 PM
Julie99toy
Jan 24, 2014 04:42 PM
Julie99toy
Jan 10, 2014 06:15 PM
djmtsu
Jan 13, 2012 08:21 AM
