engine surging
up, down, up, down, up, down and so on is called a searching idle.
Long story short, the V-6 is a pretty good motor, but if only 1 tiny problem is wrong it runs like crap. It needs to be kept just about perfect.
Ok, last time you changed plugs, wires, cap etc? Did a tune-up.. Searching idle can happen because the idle is too low, low compression, TPS (not likely but possible) tune-up needed etc...
I had 33s and a 6inch lift on my runner and I was hauling *****, but I did a few mods. Trust me good power is possible. It does good for what it is...
