Error Codes
Error Codes
Hi all, I have a check engine light on, got the codes ( P0125 & P1130)
The first is "Insufficient Coolant Temperature for Closed Loop Operation" and the other was "Air/Fuel Sensor Circuit Range/Performance. (Bank 1 Sensor 1)"
From what I have been reading, this is not "Coolant" related, but more likely has to do with one of the O2 sensors.
Any thoughts?
TIA,
Del
Any thoughts?
TIA,
Del
RE: Error Codes
You might be able to tell on the door Jam sticker.. Also can look up he VIN online.
Running hot could be a Air fuel mixture problem. These codes are only just approx usually. I would only fix one and then see and then if it doesnt work go with the other. 02 sensors usually should be changed depending on vehicle 80,000-100,000 miles..
Also what vehicle is this????
