missing and jumping
Old May 3, 2007 | 12:06 AM
ja7369's Avatar
Default missing and jumping
hi My name is jimmy i am new to the forum...I just bought my 16 year old a 1997 4runner sr5 with 3.4 in it , it is in very good shape with 111000 miles on it ...Every once in a while it will sputter for a few seconds usually on excelleration but it has also done it at idle and 1 time it didnt want to start....I need someone to point me in the right direction as to what to start with ./...I checked for codes but there is not one....Thanks
Old May 7, 2007 | 01:43 PM
mtndds98's Avatar
Default RE: missing and jumping
welcome to the board! I had the same problem with my 2000 4runner and I switched out the throttle postion sensor and MAF sensor and it solved the problem. I changed the MAF senesor because I ran a K&N airfilter and the oil from the filter coated the sensor. I hope this helps you.
Old May 7, 2007 | 07:13 PM
ja7369's Avatar
well i changed the plugs and wires and fuel filter and it solved the miss . but we have discovered a new problem , sometimes it doesnt want to start , you have to try to or 3 times and then it will start , would this be a fuel pump ????
Old May 11, 2007 | 11:06 PM
jtimports's Avatar
How does it sound when its trying to start? Could just be a weak battery, hard to say, need more info.....
Old May 12, 2007 | 11:56 AM
ja7369's Avatar
new battery , turns over fine just want start until you try 3 or 4 times
Old May 12, 2007 | 09:10 PM
  #6
jtimports's Avatar
sure you got the wires hooked up right? Distributor cap? Rotor? Possible fuel pump (but not likely) usually fuel pumps work or dont work.
SIRunner
Nov 2, 2013 05:32 AM
sirhc1179
Nov 23, 2008 08:37 AM
jjlogue3
Nov 29, 2007 07:51 AM
bdavis44
Oct 11, 2007 06:28 AM
canine
Mar 28, 2006 11:54 AM
