trailer wiring - done it?
Old Jun 27, 2005 | 12:31 AM
TonyM's Avatar
Default trailer wiring - done it?
Hi there, I have a 96 4runner and am trying hook up the trailer wires. My truck came with a hitch, but no wires... so they said at Toyota that they will do it for 240$, but I'd like to take a go at it myself. I read somewhere that the rear passenger side panel must be removed... then you needthe trailer wires and a special adapter thing that converts to 4 pin. Is there truth to this? Can anybody shed some light on the subject? THanks a lot! Tony
Old Jun 27, 2005 | 04:28 PM
Patrick's Avatar
Administrator
honestly, ive not done trailer lights on a 4 runner, but i have on other vehicles. your trailer brakes should be electronically controlled. On the vehicle i did (a motor home) theere is a male plug on the trailer, and a female end mounted to the bumper. the wiring from the female end go into the harness for the LR brake light assembly, and there is a control box which adjusts the sensitivity of the brakes, and also has an emergency button by which you manually control the brakes. s that the box that you mean?
Old Jul 17, 2005 | 12:47 PM
dtenuclear's Avatar
My 2000 SR5 came with the Toyota installed wiring it failed after a year so I bought a replacement wire set from Autozone and removed the Toyota adapter and installed the aftermrket kit from Autozone. It is easy and should cost about $50-60 if i remember correctly.</P>
vinny_vinvin
May 26, 2014 09:49 PM
unclet
Jul 5, 2009 09:21 PM
Bill
Jun 27, 2009 08:43 AM
Maine4runner
May 23, 2008 05:55 PM
rick
Aug 27, 2005 03:21 PM
