lights out....help!
Old Feb 25, 2007 | 05:08 AM
  #11
Kamakura Kid's Avatar
Default RE: lights out....help!
Well, if you don't mind running your dash lights on full bright, pull the wires from the dimmer switch and connect then with a jumper wire. If the problems persist, your dimmer switch is not the problem. If the problems go away, then you've isolated the source.
Old Mar 9, 2007 | 09:02 PM
  #12
t4running's Avatar
do you have an aftermarket radio?when does it do it(pop the fuse?)once you figure that out you may have to start tracing wires.
Old Mar 9, 2007 | 10:41 PM
  #13
Maine4runner's Avatar
I do have an aftermarket radio....I installed it three months before I started blowing fuses.....never had any troubles. I brought my truck into the dealership I work at to dio an oil leak and they replaced a valve cover and intake gasket.....and on my way home the guages and heater lights went out....the headlights worked so I assumed the taillights did too. It wasnt for a couple weeks later that I noticed the tail lights didnt work.....so I replaced the fuse and everything worked fine again...for a few minutes. There is nothing that I can seethat triggers the fuse to blow....I was going to put it into the shop for an hour of dio....but it sounds like it might take much longer if they have to trace wires....I have a friend whos a very good mechanic he just wont stop riding his sled until the snow melts.....
Old Mar 10, 2007 | 08:11 AM
  #14
lexushead's Avatar
Change your tailight bulbs.. I have seen this happen several times...If that doesn't cure it change your front marker bulbs as well...
madbull
May 9, 2012 10:59 AM
trojan
Nov 30, 2006 05:05 PM
scarecrow
Mar 7, 2006 10:23 PM
goderaj
Jan 27, 2006 01:47 AM
fvbekkum
Dec 23, 2005 12:53 PM
